-   HELP! (https://www.dieseltruckresource.com/forums/help-97/)
-   -   Engine Speed Sensor/Crank Sensor - 12 valve (https://www.dieseltruckresource.com/forums/help-97/engine-speed-sensor-crank-sensor-12-valve-150479/)
sjester May 10, 2007 04:29 PM
Trying to replace the engine speed sensor. I removed the two nuts just above the dampner. Is there another bolt that needs to be removed to pull the sensor from the harness?
Thanks
John Faughn May 10, 2007 05:03 PM
I think that what your asking is , is the harness bolted on , have not done one on a Cummins yet , but every other that had a speed sensor next to a spinny thing , had a metal strap that held the harness from getting into the balancer
, then up stream you'll find a connector .
