engine shut down at fuel throttle
Old Jan 4, 2007 | 09:45 PM
bigreddiesel's Avatar
i had the injection pump replaced with a remand one from oregon injection. the truck ran great for about 2 weeks then every time you put it to the floor it downshits and acceleratses and then shuts of. i have to put in neutral and start it back up but i have to either pump or hold the pedal. it is a 92 3/4 ton dodge diesel. it has about 400000 miles on it and the pump has about 300 miles on it. i am up for suggetions
Old Jan 5, 2007 | 02:43 AM
REF>Lancer's Avatar
Sounds to me like you are losing fuel somewhere.
maybe a leak in a feed line?...12v aint my bag!
someone will chime in soon.
Old Jan 5, 2007 | 08:53 AM
Chrisreyn's Avatar
Have you checekd the simple stuff first? the wiring at teh FSO and for leaks at the lift pump, filter and the lines/injectors?
How is it starting back up? will it fire right back up after shutting off?
I am thinking the FSO is engaging somehow... search under Fuel Shut OFF selinoid for info on it.......
Old Jan 5, 2007 | 10:29 AM
XLR8R's Avatar
Either the shutoff solenoid is doing it (probably caused by a linkage issue), or the linkages are improperly connected/adjusted... there's more than one way to physically connect them.
Someone with a runaway recently had this problem up on the board, do a search and you'll find some pertinent info with drawings, etc.
I think Infidel was one of the helpful contributors.
dkimmel
Jan 3, 2011 10:54 PM
CTDHokie
0
Mar 21, 2005 11:53 AM
Hoss
17
Nov 3, 2004 09:21 AM
Sweeper54
Aug 7, 2004 08:02 PM
dodge power
Oct 3, 2003 10:02 PM
