electrical problem
i have been having a problem with fuses blowing and running light being very dim. today i had somesmoke come from under the instrument cluster. I am in temple texas at this time and have to drive back to arkansas next week anyone no a good place to take it here?
What year truck?
What fuses are you blowing? Are you towing anything? |
99 1 ton 4x4 dually
why fuses ? no idea out of blue started happening. lost running lights replaced fuse and worked fine... then 2 under hood fuses hazard and stop light fuse happened when not towing then happened again when towing a 6x12 trailer with 1 motorcyle on it. |
The first place to check is under thr rear bumpper. I have seen were people have a big rats nest of wires and it is all messed up. Also check the tow plug for and burnt wires.
thanks guys, heard thesame from some other people today. Will get hot on it tomorrow.
Fixed the problem, traded it in and got a 2006 quad cab 3500 sw ctd, aut o[guitar]
well, that's a pretty good way to fix it.
