BD-Power Exhaust, How does it fit ??
???HELP !!! I can not figure out how the tail pipe strap fits. It's about a foot away from the factory strap. Where does this attached to ?? Any Ideas anyone ??? The directions w/ this kit are horrible. Their tech help doesn't seem to be either. <br>Any hints would be appreciated.
Re:BD-Power Exhaust, How does it fit ??
I had BD-Power in Abbotsford install mine and they added a rear hanger which mounts about 8 inches or so behind the rear spring mount. If you want, get back to me and I will go out and make some measurments and get it more exact.
I found a hole in the frame, way up , between the old hanger and the leaf spring. I had to locate a bolt that would fit, as it didn't come with the kit. So now it's installed, but the hanger and the pipe clamp just hook together and rattle at idle. I think I'll have the two welded together to eliminate the rattle.<br><br>Thanks for your reply.<br><br>Ray<br>
Redwood logger
10-08-2009 09:27 PM
GR40RCapri
11-29-2006 10:14 PM
dodgedude361
04-08-2005 03:42 PM
KATOOM
05-23-2003 05:58 AM
