Driver's door won't unlock!!!
...All other doors will unlock but the driver's door will not unlock using the remote or the key. There is no sound and the key won't turn.
I have removed the lock/latch unit but cannot get it to function. My 3/36 is expired as it happened at just under 41,000 miles so warranty is out. Suggestions on where to get a replacement other than dealer hopefully. TIA!!! |
That should be readily available at a salvage yard for cheap. You will need to get it re-keyed at a locksmith though. Should not be an expensive job.
Originally Posted by amartinson
(Post 1175058)
Thanks for the replys. I started checking salvage and there wasn't much available in my area that I could find. So I did go to the dealer just to "price" it out. Turned out to be just under $50 with tax. I went ahead and ordered it.
| All times are GMT -5. The time now is 11:52 PM. |
