Computer my be dead
Old Jun 15, 2006 | 09:55 PM
BIGROD's Avatar
There is one place on the internet that does the ECM's but they still have to be flashed. I can't remember what the company name is.
What codes is show up when scanning?
Cummins has a way to check the ECM's with a voltmeter. The check list is a 5 or 6 pages when printed out.
Rodney
Old Jun 15, 2006 | 10:39 PM
BIGROD's Avatar
Make sure the used ECM has the same ECM Code or ir will have to be reprogrammed. This can be found on the ECM plate that Cummins puts on the ECM.
With the P1689 code there are alot of thing that could be the problem.
What is the fuel pressure and flow from the lift pump? If you were running with low pressure the VP44 is mort then likely going out.
If you have a Cummins Dealer close see if they will give you a copy of the ECM check. They will try to tell you there is not one, but there is.
Old Jun 15, 2006 | 10:50 PM
RCW's Avatar
RCW
The 1689 is usually attributable to the processor in the VP44 injection pump kicking the bucket, not the ECM.
Old Jun 16, 2006 | 07:51 AM
KITCHEN's Avatar
Auto Ecm Electronics 2701 S. Great Southwest Pkwy. Grand Prairie, Texas 75052 It Will Cost You About $400 Including Flash To Rebuild Your Ecm.. Been There Done That..
Old Jun 16, 2006 | 10:23 AM
dctoner's Avatar
Brian,
Explain the times it does and does not start. If it sits for a while will it start, what are the outside temps when it will and won't start.
I'm not saying this is your problem, but on my second LP it went to 0 psi before I discovered it was bad, My IP is now dieing, in the morning it starts great but after about 20 min worth of driving it won't start unless it sits and cools off for about 3 to 4 hours. When it is above 90* outside it doesn't like to start even if it has cooled off for a while.
Just something to keep in mind
600 Megawatts
Mar 26, 2008 07:09 PM
Jvenne86
17
Mar 20, 2007 08:27 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
boomer
Nov 28, 2005 07:58 PM
