clunk
Old Sep 29, 2006 | 07:13 PM
MADMATT's Avatar
clunk
what kind of things can cause a clunk while backing up ? need some ideas to look over the truck
Old Sep 29, 2006 | 07:17 PM
P.J's Avatar
P.J
Universals, diffs, maybe a carrier bearing, a cat, hitting the garage, any number of things.
Does it do it going into reverse, or while backing?
Old Sep 29, 2006 | 07:20 PM
MADMATT's Avatar
does it while backing up front end kind of noise is where it is coming from
Old Sep 29, 2006 | 08:15 PM
MADMATT's Avatar
could it of been my downpipe rubbing on fire wall the exhaust clamp was a lil loose
Old Sep 30, 2006 | 06:23 AM
P.J's Avatar
P.J
Any marks/scratches to indicate so?
Old Sep 30, 2006 | 09:56 AM
XLR8R's Avatar
No clunk when starting forward?
I'm assuming you're in 2WD...
What's the problem with your water/meth?
Old Oct 2, 2006 | 02:23 PM
phabib's Avatar
loose bolts on one of the connections between a driveshaft and a diff or transfer case.
Cummins610
17
May 29, 2010 12:50 AM
MasseyMan1089
May 23, 2007 07:56 PM
dpeder
Feb 21, 2006 11:34 AM
blh1960
Aug 29, 2003 10:00 AM
slimchase
0
May 14, 2003 10:06 AM
