Check Engine Light
Old Apr 26, 2004 | 12:28 AM
DrJeff's Avatar
Originally posted by 4doogie
this is a stupid question, but where is the intake air sensor? is it on the EGR? how long does it take to fix it?
4doogie, It was only a week ago that I didn't know where the intake air sensor was. After studying my Haynes manual that covers a little bit of all Ram motors (there is probably a better manual out there) I found the intake air sensor on top of the intake manifold (driver side of motor) toward the firewall. You will see a sensor threaded into manifold, pull the wires and use a deep socket to remove. Mine was packed with carbon soot, I just tapped it with a screw driver and after all the carbon fell out I could see the actual sensor element when I was done. It took me all of 10 minutes (I'm an amateur mechanic) and the check engine light has not come on since. Good luck, let me know your results!
_97 2500 4x4 CTD CC 252,000 mi Strong, Auto Trans weak link. Second owner, first owner not mechanically inclined as I continually discover. 04.5 HO 600 is in my future, I'm hooked on CTD.
Old Apr 26, 2004 | 12:43 AM
4doogie's Avatar
thanks, i didnt want to un-do the wrong thing. i would scrap the whole thing but that seems to be to much work. thanks again i will let you know if it works
buddy26
Feb 15, 2008 12:17 PM
choppers555
Oct 16, 2007 12:29 PM
alltimelow1
Apr 6, 2005 07:28 PM
Fillerupsonny
Oct 9, 2002 06:01 PM
