Check Engine Light
Old Feb 14, 2008 | 07:13 AM
DieselResearch's Avatar
Check Engine Light
Yesterday i went out and cleaned off the truck. It was idleing for about 15 minutes while i cleaned it off. The truck ran fine, and everything was good. This morning i went out and started the truck and it threw the check engine code as soon as it fired up.
I have a 94 ram 1500 and you could turn the key three times and read the flashing check engine light. I did that on my 06 ram 2500 and it flashed 10 times in a row then stopped. Is there a code 10?
Could someone tell me how to show and read the fault codes with the check engine light? Maybe i am doing something wrong.
I am planning on taking it to the dealer tomorrow, but any help would be appreciated. I want to make sure its nothing major.
Last edited by DieselResearch; Feb 14, 2008 at 08:55 AM. Reason: additional information requested
Old Feb 14, 2008 | 10:48 PM
Cummins610's Avatar
When you do the 3 times key thing look at the odometer, thats where you will get a code
Old Feb 15, 2008 | 06:43 AM
Duh!!!
After looking at the odometer i read the code P0111 (Intake Air Tempurature Sensor Rationality).
I called the dealer last evening and they said it wasn't a huge deal and made an appointment for next week.
Would this sensor cause major issues if the truck is still run?
Old Feb 15, 2008 | 07:15 AM
Foxborough's Avatar
I've never have gotten the 0111 intake air code but I usually get the 0514 & 0071 battery temp & air temp rational. They usually go away after a few normal starts. Mine usually go way in a few days. I bought an Actron OB II scanner from Auto Zone, just to view the codes when they come up. You can clear the codes with it but I just let them go away on their own. Sounds normal assuming it's a daily driver and it goes away in a few days. I usually get my temperature codes in the spring & fall, once or twice a year when temperatures swing up and down.
Old Feb 15, 2008 | 09:18 PM
sweeney186's Avatar
Ecm update will take care of it-covered by your 5/100 warr.
buddy26
Feb 15, 2008 12:17 PM
choppers555
Oct 16, 2007 12:29 PM
alltimelow1
Apr 6, 2005 07:28 PM
Fillerupsonny
Oct 9, 2002 06:01 PM
