Check Engine Light!!!!
I heard what sounded like mud/sand kicking up from under my truck (dry paved road), it lasted too long to be mud/sand. Immediately after, check engine light appeared. After bumping these codes P0483 and P0336. Any ideas? The truck seems to run fine. Thanks.
Do a search and find out what the codes mean. It definately sounds like something came apart so I'd spend some time crawling around under the truck before I drove it to look for something amiss. Don't rely on the fact that it still runs - a serious breakdown could be just around the corner. On the other hand it might be simple. Just research the codes and look until you are satisified that you know what happened.
P0483 Cooling Fan Speed
I would inspect the area underneath to see if I ran something over that would have knocked something loose. Then, pour another cup of coffee.
I didn't run over anything. I didn't pull over either. I will check the belt to see if it came apart. I also just had the truck in for a problem yesterday. The front right diff is leaking, fluid is jet black. I just had all my fluids replaced about 4,000 miles ago. Dealership ordered seal, come to find out the whole diff has to be removed to the left side to replace the right. Now I have to wait for the left seal to come in. UGH!!!! Could this cause the driveshaft code? Thanks....
buddy26
Feb 15, 2008 12:17 PM
choppers555
Oct 16, 2007 12:29 PM
alltimelow1
Apr 6, 2005 07:28 PM
Fillerupsonny
Oct 9, 2002 06:01 PM
