Brake lines
Old Feb 1, 2007 | 01:08 AM
swabjockey's Avatar
Angry Brake lines
Just left work and was driving out of the lot and bang , brake ped.l went to the floor. got out and saw fluid dripping out from the left rear frame rail hard line went so. My ?'s are does anybody know who sells the hard line for the rear brakes other than the dealer?
I am in Rhode Island
Tom
Old Feb 1, 2007 | 02:14 AM
Marine's Avatar
Veteran: Marine Corp
I would think the dealer would be the only place.
Another option would be to get one made, but the dealer route would definitely be easier. No doubt it will be more expensive.
Old Feb 1, 2007 | 04:09 AM
6WHEELER's Avatar
If you are talking about the the line from the front to the back, my dealer couldn't get it. went to the parts store got 3pieces(72in,60in and 18in, i think) sticks of steel brake line and connectors and made it. Had about 2in of excess, mine was rusted real bad behind the tank. my is a quad cab long bed
Old Feb 1, 2007 | 08:12 AM
TIMMY22's Avatar
go to napa. It probably between the fuel tank and the frame.
Old Feb 1, 2007 | 08:28 AM
b.lee's Avatar
I second the napa.
It's cheap and works great.
and it was in stock when I needed it.
Old Feb 1, 2007 | 08:35 AM
DL1221's Avatar
Yup, I think those steel brake lines are obsolete at the dealer, at least the ones for my 96 were.
If you don't mind the expense, and want the best, get stainless steel. Classic Tube and Inline Tube both have them, but they not cheap.
Old Feb 1, 2007 | 03:53 PM
JKM's Avatar
JKM
Napa , get a roll of tubing , and a couple of the correct end fittings, get a double flaring tool while your there if you don't have one. Make your own line.
Old Feb 1, 2007 | 04:08 PM
Hayseed's Avatar
I vote NAPA, mine went out and I just used a piece of line and two compression fittings. They will not leak if you clean the old line where you cut it. At work we have 3000 psi compressed gas going through compression fittings and no worries. Easiest and quickest fix .
Old Feb 1, 2007 | 04:11 PM
Crimedog's Avatar
Making your own is not difficuilt at all. A double flaring tool will run you around $40 or so but it is worth it. You want the double flare because it will seal better and have less chance of leakage. Oh, and you'll want a cutting tool, they're generally pretty cheap though. Less than $10 I would imagine. You could make the lines and buy the tools for pobably pretty close to what it would cost you to buy the line pre-made.
Old Feb 1, 2007 | 06:25 PM
Dartsport's Avatar
In Pennsylvania, you can't use compression fittings on brake lines!! Won't pass a legitamit inspection!!
MrKen
Feb 25, 2005 04:22 AM
AlpineRAM
Oct 9, 2003 03:53 AM
Tartarus
Oct 1, 2003 02:36 AM
hellotbone
Sep 1, 2003 08:46 PM
93w250
Dec 20, 2002 07:06 AM
