Brake Help!
Old Oct 12, 2005 | 10:02 PM
mhuppertz's Avatar
Good point
I am surprised that the PCM doesn't throw a code when the dump valve is malfunctioning. It's kind of a dangerous situation!
Old Oct 13, 2005 | 03:40 PM
mhuppertz's Avatar
Update: I am picking up a new dump valve from Napa today. The online one was cheaper, but a week away. Napa in Albuquerque only had one, and it was at the main warehouse downtown!
I guess I'll try to get that booger in this weekend.....
Old Oct 14, 2005 | 09:47 PM
mhuppertz's Avatar
Crap! It looks like this new valve has different mounting stud pattern!
I don't know yet if everything else is the same. I'm going to look it over really well in the morning...
Old Oct 16, 2005 | 06:28 PM
timcasbolt's Avatar
might be overthinking the problem
Before changing any more parts, I'd be bleeding and re-bleeding the system. You're describing air in the system. One little bubble can cause all kinds of problems.
Old Oct 17, 2005 | 08:19 AM
mhuppertz's Avatar
Thumbs up Update
The new ABS hydraulic dump valve just had an extra stud, but it's identical to the one I pulled out. The main brakeline was fused to the nut, so of course it twisted off. I had to drill out the flare nut, get another piece of line and a union and make a splice. Sure glad I have a tubling bender! Anyway, got it all on last night, and with the exception of all the air in the lines now it's working better. I am going to have the brakes power bled today. I hate bleeding brakes with a passion! Thanks to Wanna for the call on the valve.
Mark
Old Oct 17, 2005 | 08:11 PM
mhuppertz's Avatar
Felt guilty, so my wife and I bled the brakes. I bled about a quart of fluid through the thing and it does feel much better, but I'm still getting pedal leakdown. It's a lot slower and stops sooner, but it is bleeding down some. I'm starting to think there is a taper in the Master Cylinder bore. I should have gone with a new one!
Old Oct 28, 2005 | 09:10 PM
mhuppertz's Avatar
Update
Master Cylinder worked out it's issues overnight, but front brakes started grinding on drivers side. I guess driving without the rear brakes because of the dump valve malfunction fried the fronts.
The inside of the drivers rotor had gone metal to metal, and was wounded, so I put one of my used sets on the truck to smooth out the rotors a bit before I put the new carbon metalic jobs on there. I also adjusted the rears (they were way out) and now the brakes are solid.
I don't know how to tell how much brake lining is on the rears without pulling out the axles.
I wish somebody would design front and rear brake rotors and drums that can come off independently of the hubs. I really hate this setup
dieselluvr
Dec 29, 2013 11:02 PM
mr T
Oct 16, 2005 07:38 PM
ddestruel
Apr 6, 2005 11:26 AM
wvcowhauler
13
Apr 3, 2005 11:39 PM
