borgeson steering shaft install help
Old Sep 29, 2007 | 10:02 AM
rjm022's Avatar
shaft is disconnected at both ends-(steering box and inside cab, by firewall). the problem i can't figure out is how to get the shaft out through the firewall!! i don't see a set screw on the oem rag joint to take it of, so just the shaft passes through the rubber grommet. i tried to remove the big rubber grommet, but that did not work-does not look like it can be taken out and put back in. any suggestions??
Old Sep 29, 2007 | 12:14 PM
rjm022's Avatar
got the shaft out- compared it to the borgeson- the borgeson is a good two inches shorter, even when extended?? what is going on here??
Old Sep 29, 2007 | 12:23 PM
bob4x4's Avatar
Call your vendor,I have seen others having problems with their 3rd gen stuff,including the splines not being correct at the gear box
Bob
Old Sep 29, 2007 | 12:56 PM
rjm022's Avatar
i did- shaft also does not fit on the splines!!! getting an ra number as we speak
Old Sep 29, 2007 | 01:57 PM
rjm022's Avatar
extended length is 30 inches-that is the correct length for the 950 model for my truck- but it is a good two inches too short! i do not understand this!
Spitse
Aug 27, 2010 07:19 AM
bogman
Mar 5, 2009 04:50 PM
rjm022
Sep 29, 2007 01:59 PM
GIT-R-DONE
Feb 11, 2007 11:15 AM
Raspy
Oct 31, 2003 01:17 PM
