Oh crap i put E85 in my truck!
Old 09-29-2008, 10:04 AM
stickman73's Avatar
While talking to my wife on the phone i stoped to get fuel and grabbed the yellow handle and starting pumping, i got 10 gallons in before i noticed what i did. So if i have to drain it does anybody know if there is a drainplug or can i use the fuel pump to pump all of it out. Or do i need to completely drop the tank? Any and all help would be greatly appreciated.
Old 09-29-2008, 10:18 AM
Mrlou's Avatar
Mity vac makes a nice fluid evacuator comes with small diameter draw straws in the kit part #07300 works with shop air . You should be able to draw most of the fuel out through the fill line.This thing works fast well worth the money. Then just fill it up it is alot easier than taking everything apart.
Old 09-29-2008, 10:22 AM
87BRGN's Avatar
I would drop the tank. Even if the motor wasn't running. I think 10 gals of E85 is a little to much to try diluting with diesel. It might be a pain in the tail, But that cummins wont like that E85 one bit. Drain the tank, get some fresh fuel in there. If you did run the truck, remove the lift pump to injection pump line and get fresh fuel there before you hook it back up and I think you'll be good to go.
Old 09-29-2008, 10:24 AM
infidel's Avatar
Don't know if '06 has a rollover ball that blocks getting a siphon hose down the fill spout but if it does easiest way to drain the tank is to crawl underneath, remove the fill hose from the tank and siphon it out from there.
I wouldn't drive it and wouldn't worry much about getting every last drop out or changing the filter if you haven't started it, just fill it up all the way with #2 before you do.
Hopefully the station will let you dispose of the mixed fuel.
Old 09-29-2008, 11:03 AM
stickman73's Avatar
Thanks for all the answers. I will be removeing the filler hose, and siphoning out the fuel, then opening the drain for the filter and cycling it a few times then changing the filter and filling it up. Also i will be running some power service cleaner and 2 cycle. Should be fine after that. Thanks to all.
Old 09-29-2008, 11:50 AM
97 D-Tec's Avatar
ha and my gf said women arent a distraction
Old 09-30-2008, 01:25 PM
Farmboy89's Avatar
Grandpa put gas in dads one time and drove it.... We had to drop the tank completely drain it then put it all back together. Once diesel was put back in it ir ran rough for 5 min. hitting and missing but finally smoothed out and ran.
Old 09-30-2008, 01:33 PM
Danderson's Avatar
I did it.
I did the same but with 7 gals. of 87 octane. Had it towed to the dealer and made out fine. They discovered a collapsed tank(this was my old '99) due to failure of receiving dealer to remove a cap on the tank vent which keeps crude from getting in under transport. They put in 5 gals and I prayed all the way to the nearest station.
Old 09-30-2008, 03:32 PM
renopker's Avatar
are you one of them that talk and drive to?
Old 09-30-2008, 03:59 PM
New_Dog93's Avatar
Sounds like a familiar tale! I'd owned my '93 for 3 hours when the pump jockey at the FasGas filled it with regular! I never turned the engine over so all we did was crawl underneath to separate the filler hose from the tank. We siphoned out all we could, hooked the hose back up and put 10gals of diesel in the tank. That was several tanks of fuel and many miles/kilometers ago.
Old 10-01-2008, 01:23 PM
DIESELRYAN3500's Avatar
sorry, there is a blue ball that will not allow you to siphon out the fuel. youll probly have to drop the tank unless someone knows a quiker way.
Old 10-02-2008, 06:45 AM
Mrlou's Avatar
just disconnect the fill tube from the tank and siphon away.
Old 10-02-2008, 07:31 AM
Mlucas's Avatar
I've siphoned fuel out of my 06 before-not a big deal-but you'll never get the bottom of it clean with a hose.
Do what you said & siphon out of the pickup tube-the return tube stops at 3/8 of a tank...so make sure its the pickup one.
Old 12-03-2017, 12:29 PM
Jessica Solis's Avatar
F-250 Superduty '09
Last night I was at a gas station and I accidentally put like 2-3 gallons of 85% Ethanol in my husbands diesel truck, I caught it quick when I realized the pump was yellow and not green but when I asked the store employees they said just to dump it in the back, this truck doesn't have a fuel drain so the engine would have to be dropped, i called my husband and he said it should be fine it was a small ratio of 2-3:28-30 gallons. So I went back in side and canceled that pump and another truck towed mine to the diesel and I filled it up, it turned on good and I sat there for 30 min and it was good, it ran good for about 2 miles when I got to the house.
Now (4 hours after the truck was driven with the fuel mix) I turned it on and it was making a weird noise but it was running.
anyone know if this is good, like if it's just burning the gas, or am I totally screwed and we're looking at a new engine?
Old 12-04-2017, 08:55 AM
johnh's Avatar
it should be ok, just keep it full, i would put a gallon of 2 stroke outboard motor oil in the fuel tank
.boB
06-22-2012 12:47 PM
barngal6
07-05-2009 06:49 PM
Spooler
48
12-02-2008 03:28 PM
12PACK
01-18-2006 01:28 PM
Quick Reply: Oh crap i put E85 in my truck!
