bad rod barrings
Old Oct 2, 2009 | 11:45 PM
jsemeraro's Avatar
bad rod barrings
i think i have bad rod barrings, how hard is it to change on a 2nd gen? do i need to take the engine all the way out?
Old Oct 2, 2009 | 11:50 PM
06RAM2500's Avatar
Once you spun a bearing, total dis-assembly, overhaul, and reassembly is required. It'll have a distinctive knock and you will still have oil pressure cause the bearing welded itself to the crankshaft.
Old Oct 3, 2009 | 09:06 AM
rich's Avatar
you could do it in frame but it would be a pita
Old Oct 3, 2009 | 09:19 AM
annabelle's Avatar
Spin a bearing......turn the shaft it was on. Break her down and do it right.
ddestruel
Dec 7, 2008 06:37 AM
Badd Dogg Guy19
Jan 18, 2008 09:19 PM
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
