AX. Fuel pump
AX. Fuel pump
I was in a bind the other day. The holly blue pusher pump was going out and I had to in south TX that afternoon. I was not able to get another holly so I settled for a Carter.
The one that I got puts out 100GPH @ 15 PSI. It seems to work well for now (about 20 PSI at 70MPH) but I am concerned about when I have to pull a trailer and will need extra fuel will this pump be sufficient?
Thanks
Thanks
Hard acceleration with a load is the test...That is when the motor is using the most fuel and will pull pump pressure down as it uses more volume.
To get an idea about how the pump is keeping up...While the truck is empty, climb a hill or use a freeway on ramp and get the egt's >1000, and keep an eye on fuel pressure. If it says above 10, you are likely to be OK. If it is 5-10, probably OK...should be meeting stock criteria. If <5, back out & take it easy.
Then, repeat the same test with your load. Same criteria.
Oh, and fill out your sig so we know what you have!
HTH
Tony
ScreaminEagle
Oct 31, 2007 03:31 PM
Commatoze
19
Aug 8, 2004 09:57 PM
TPilaske
16
Nov 22, 2002 08:15 PM
