Automatic tranny question (DTT)
Ok guys I have my own tranny but with the DTT resistor. I intalled it last night as per instructions and it works properly. However I am suppoed to be at 4.0 volts but when I put it down that low my tranny shifts mushy. If I turn it up it shifts normally hard like it used to. My question is if I turn the voltage down again and turn the governer pressure up can I turn the pressure up even more and get a harder shift? I have not tried it since I turned it up on the highway to see if I get limp mode. I drove it to work at 100 km/h with no probs.<br><br>
Re:Automatic tranny question (DTT)
I can't supply the info you're seeking. However, I do suggest calling Bill Kondolay (DTT) or others well versed in modified transmissions.<br><br>Jerry
Try going to DTT's web site www.dieseltrans.com , then go to his tech fourm, Bill's helped me a few times online. ;D
