antifreeze pouring out
ne1 know the cause of antifreeze pouring out the pass side bottom front below generator ne1 have any advise?
is this the block heater loose i read about?
Most likely. I believe all it takes is a wrench to tighten it up.
i checked the block heater bolts they didnt feel loose any ideas?
Get under there with a good light and inspect the drain hole on the water pump. If the pump seal goes, coolant will run from that port. The other places to look are the thermostat housing (above the alternator and next to the block), and the oil cooler cover (which is also the mount for the oil filter).
thx i got it needed new water pump easy change 15 min also the cheapest thing ive done only 36.99
