24 valve charging problem
Old Nov 16, 2009 | 02:26 PM
hiatt426's Avatar
So I have a 98 24 valve that has a new alternator, new terminal ends, and new batterys. it will stay charged, but it doesnt charge it any more than 9 or 10 volts. im thinking it is a bad voltage regulator. so any help is appreciated. oh, it does have an engine out of a 2000, i dont know if that would affect much of the problem or not.
Old Nov 16, 2009 | 04:39 PM
cmac's Avatar
you might want to check the crank sensor. i'm pretty sure that it can cause a low or no charge situation.
Old Nov 16, 2009 | 06:18 PM
hiatt426's Avatar
so just to help diagnose things I just ran my own wire on a toggle to the field supply post on the alternator and it charges just fine. but the "check guages" light still comes on. I dont care too much about the truck, I think i will just put on a diffrent voltage regulator. what are your thoughts?
Old Nov 16, 2009 | 07:34 PM
cmac's Avatar
i thought these trucks have internal voltage regulators?
Old Nov 16, 2009 | 08:08 PM
rebal's Avatar
check all your grounds and connections the pcm can cause a no /low charge too
Old Nov 17, 2009 | 07:22 AM
patdaly's Avatar
Internal to the PCM...........
Old Nov 17, 2009 | 07:34 AM
cmac's Avatar
well now that aint no fun...
Diesel-Dan
20
Sep 22, 2019 09:34 PM
GLHS
Feb 25, 2011 10:12 PM
Smokin96_12v
Jan 21, 2010 01:06 PM
smokinjoe55
Dec 18, 2008 06:20 PM
freeloader
15
Nov 26, 2003 02:01 PM
