Help me stuck on side of road
Old 09-20-2017, 06:47 PM
Robert Dull's Avatar
I have a 2001 Dodge diesel 5.9 Diesel I'm stuck on the side of the road I have a 38 ft toy hauler on pulling with it it lost all the power and surging really bad making the truck jump up and down and trying to get the trailer off the road seems to run fine when I'm sitting but I took it for a ride in about 30 minutes later I noticed a slight surge what can I do to fix that or what can I do to look for my problem I'm in dire need for help
Old 09-20-2017, 07:48 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
You replace fuel filter yet? Air filter ? can you hear fuel pump running?
Old 09-20-2017, 07:56 PM
Help me I'm stuck on the side of the road
I haven't change a fuel filter I changed it I had a shop do it about a year-and-a-half ago maybe the air cleaner is showing barely a little red on the bottom of the warning emblem warning thing
Old 09-20-2017, 07:59 PM
I have a 2001 Dodge diesel 5.9 Diesel I'm stuck on the side of the road I have a 38 ft toy hauler on pulling with it it lost all the power and surging really bad making the truck jump up and down and trying to get the trailer off the road seems go run fine when I'm sitting but I took it for a ride in about 30 minutes later I noticed a slight surge what can I do to fix that or what can I do to look for my problem I'm in dire need for help
I haven't change a fuel filter I changed it I had a shop do it about a year-and-a-half ago maybe the air cleaner is showing barely a little red on the bottom of the warning emblem warning thing no I can't hear a fuel pump I've been wondering if I have manual or electric fuel pump in this truck
Old 09-20-2017, 08:16 PM
Cummins Guru
BigIron70's Avatar
2001 is electric and you need to just bump the starter and pump will turn on if working and run for 45 seconds. If you never replaced fuel pump that is most likely your problem. Pump is located just below the fuel filter housing. If you are near auto parts store you can try replacement pump, fuel filter and air filter. Try pulling filter and bump starter so pump will turn on then see if you get fuel flow to the filter.
Old 09-21-2017, 01:48 PM
johnh's Avatar
the pump is located behind and below the fuel filter housing.
Old 09-21-2017, 02:48 PM
Just a plain ole guy
1-2-3's Avatar
I change my fuel filter every other oil change.
Old 10-07-2017, 05:29 PM
Vendor - Former Vendor
ecmexchange's Avatar
Did you ever find out what was wrong? I'm having very similar symptoms with my truck.
Old 10-07-2017, 06:26 PM
MAC702's Avatar
And did you also try the first piece of advice for this?
Change the fuel filter first. It's cheap and easy, and eliminates a common cause.
birdboy
12-12-2018 09:02 PM
bannerd
05-26-2012 10:30 PM
91rangerturbo
12-20-2008 07:07 PM
Baja
01-29-2008 08:17 PM
cquestad
06-14-2006 04:49 PM
Quick Reply: Help me stuck on side of road
