2003 Dodge 5.9l cummins hard start or no start
My lift pump and injection pump was replaced still hard to start or will not start. When running no smoke white or black lots of power idle is good does not run rough.
start saving your money for injectors
Originally Posted by rich
(Post 2594264)
135,200 miles
miles dont matter had mine go out a little over a 100k then the next set go out in less then 25k. You either need to put a rail pressure gauge on it and see what the pressure is when cranking should be at 6k or do a flow test to see if it is the injectors
