1991 Dodge D250 Cummins charging problems
Old 06-26-2019, 10:47 AM
Stuiebaluie's Avatar
Have replaced alternator, voltage regulator, and battery twice! Still having problems with over charging. Anyone have an answer?
Old 06-27-2019, 10:22 AM
BlueW250's Avatar
Assuming you still have an external voltage regulator this is my best guess:
https://www.dieseltruckresource.com/...solved-317745/
If the reference voltage to the regulator is low due to voltage drop through the aging wiring and connectors the regulator tells the alternator to charge the battery. This thread addresses pulsing but if the drop is enough it can charge continuously.
Good luck,
BlueW250
Old 06-27-2019, 11:14 AM
Received 2,392 Likes on 1,576 Posts
Good luck,
BlueW250
Just had the same issue with the reference voltage on my black '85 crew cab that uses a '91.0 wiring harness. I had voltage that was running high and bouncing.
Re wiring the signal to the VR fixed my issue.
Old 06-27-2019, 03:36 PM
maybe368's Avatar
Good luck,
BlueW250
Interesting, I have just lived with the pulsing for only about 19 years or so. The other thing is that is the same relay that I used to excise the problematic KLIMA relay on my '86 Mercedes 300 SDL . It is wired into the AC system and monitors 7 or 8 different sensors that all can shut down the AC system, a real PITA. I really like things as they were made at the factory, especially on classic or collector cars but trouble shot until my eyes were bleeding even though I had already found the relay fix. About 8 bucks and 10 minutes after I got the relay, the problem was solved, no KLIMA and cold air . For me, the really cool thig is there are no permanent modification and if someone wants, the KLIMA can be replaced...Mark
1991 red dodge
01-31-2019 04:08 PM
beater
10-30-2010 09:29 PM
mw66nova
05-13-2009 05:28 PM
SRich
10-16-2007 03:46 PM
Quick Reply: 1991 Dodge D250 Cummins charging problems
