11 ram ran 5 minutes now no start no codes
Started my truck remotely, warmed up for 5 minutes...keyed in and went to hook up trailer 100 feet away. As i backed up tge truck just died and will only crank but no start. Not throwing any codes either. Have full deletes with xrt pro in stock setting(waiting to break in motor). Tried reloading software, same result. HELP!
Sent from my Droid using Tapatalk
Yes...it finally started with a rough idle....up and down rpms...not a miss....got it about 50 feet before it died again.
you should be able to hear it if you bump the starter, you should hear it run at the tank. There was another member with a similar issue and his truck didn't have a fuel pump fuse.
Chaser10
23
02-20-2018 03:26 PM
peanut
02-07-2010 08:45 PM
Vintage Empire
09-18-2007 09:43 PM
