06 cummins wont run
what is a po513 code?????????
HO513??
Cycle the key on/off 3 times. On the third key on, look in the odometer window for codes. |
possible key cycle will not pull codes because 513 is invalid skim code
GENERAL NETWORK ERROR KEY NOT PROGRAMMED INCORRECT KEY INCORRECT VIN IN ECM OR SKIM LOSSS OF COMMUNICATION BETWEEN ECM AND SKIM |
