03 dodge R.I.P
im running out of ideas the truck is a 03 dodge with 135,000 on it. I have the edge aditude with ez, intake, exaust stacks, and methenal.
i have a feeling my ecm got f up by the edge it wont start now for the second time the first time i just cleared the codes and put every thing back to stock and it worked and now i hooked every thin back up same thin happened , wont start so i put everythin back to stock and tryed to clear everythin no it wont work it will crank but wont start any ideas would be apresated theses tow bills are addin up ouch |
Are you sure the engine is getting fuel?
uve been getting it towed to the shop and they can't figure things out?....can u even crank or is it clikcing? if u are cranking are u getting fuel at the injectors?.....which fuel pump do u have? the vp44?
u cleared the codes? what were the codes? |
