What needs fixing on your truck right now?
Brakes and heatercore in that order[laugh].
A/C recirculation door
Tach and a burned out dash light.
trans......
So far nothing major:cool:well except my heater core.
Clutch. still works fine but the smarty will soon kill it.[coffee]
Oh and almost forgot. TIRES also killed by smarty. |
Originally Posted by Fire Rescue124
(Post 1708651)
I actually fixed my leaking oil return tube from turbo today...its only been leaking since I did the hx35 in JULY! Still need to bump timing, but its getting closer. We LOOKED at the nuts today [coffee] |
My charger is MIA :D
Brandon |
hi
lower right shock bolt worn causing a rattle, radiator tank joint leaking , tires bald , do a headlight upgrade , get deiver side seat coushin repaired . must u go on ?? |
get driver side seat cushion repaired . |
Have to pop the hood to turn the engine off. One day that will be fixed.
That still makes me laugh my man [laugh]
I'd say fix the oil leaks but then it wouldnt feel like a Cummins. Oh, and rebuild the front end, yet again.[duhhh]
Tires need replaced and I think the brakes are starting to go
Driver side lower ball joint...which means I'll end up doing upper and lower on both driver and pass sides. They're still the original ball joints with just over 80000 mi on them. Pass side is still good, but, I know if I only do the driver side then the pass side will need them a week later thanks to good ol' Murphy. I may look into shocks too. I suspect they're getting a little weak. Not bad, but worth changing out.
