Water spots on wheels
Might be a dumb qustion but please tell what product someone uses to take water spots off these aluminum wheels. They are a pain in the butt.
Elbow grease
Not sure about a spray on and wash off product that will not damage the finish.
Get you some good polish and set aside some time. When nice a pretty put a good coat of wax on them.
Well this may help. Try putting some armorall on your tires, then use the overspray after it settles and polish the wheel with it. I know it helps me get rid of stubborn water spots on my chromies, maybe it will help you too.
If your wheels were hot when you washed them, you might have a tough time getting rid of them. Next time you come home after a long drive (hot wheels), wash and dry them again. The pores in aluminum open up when hot. If you spray a hot wheel with cold, unsoftened water, it will stain the wheel.
When you polish a wheel with a buffer and rouge, you have to get the RPMs fast enough to generate the heat required to open up the pores and get rid of the oxidation.
Graphite600
12-01-2004 04:56 PM
