U joint broke and broke transfer case.
Old 12-26-2009, 06:16 AM
Hodge's Avatar
The case isn't the trouble- the driveshaft coming loose is. Regardless of the case, a u-joint smacking into it is going to damage it.
So, whether it is the light duty or the heavy duty, doesn't matter. A hole is a hole. The heavy duty transfer case will be just that much more expensive to replace.
Unfortunately, mine doesn't have a nickel-sized hole. It has a fist-sized hole.
Old 12-26-2009, 07:08 AM
catnfool's Avatar
yeah, a fist sized gob of silicone would make me a little ashamed; you would NEVER let anyone under your rig for ANY reason
kind of like letting someone else work on your dodge and leaving bolts loose...
Old 12-26-2009, 10:06 PM
Hodge's Avatar
No kidding.
A t-case is on its way from Missouri. No fist sized gobs of silicone for me.
Old 12-26-2009, 10:27 PM
ILLINOISRAM's Avatar
we had the bolt vibrate out of our 4 bolt flange and put a fist size hole in the dld transfer case. We just jb welded a peice of sheetmetal back and it still handles 600 horse pullin just fine.
Old 12-27-2009, 01:05 AM
catnfool's Avatar
jb weld needs to watch your video; I think you might be their poster child!!! Was that AFTER your repair? looks good!!
Old 12-08-2017, 01:32 AM
Jake in va's Avatar
Originally Posted by smokeum99ta
My u-joint on the front drive shaft broke, hit the ground, and ended up breaking the transfer case. Anyone have a place to buy another transfer case in Maryland?
Stupid question but how long can you drive after this happens. Mine broke same exact way. Drove home no issue but I want to drive it to shop to be repaired. Can I risk it?
offroad
08-16-2011 10:42 AM
GraveDigger1
11-07-2010 07:28 PM
smokeum99ta
MDDTR #33
12-22-2009 05:41 PM
suttonbeeman
05-24-2005 10:38 PM
Quick Reply: U joint broke and broke transfer case.
