Radiator
Push and turn clockwise. They're plastic, so you have to be careful; a lot of people have broken theirs. Spray it with a good penetrating oil like PB Blaster before attempting. BTW, WD-40 is not a penetrating oil.
I read an article on this very thing , and in the article it said to remove the female part of the plug that was still in the hole, and then find a long bolt with the same thread pattern and insert it into the hole and thread it into the nut inside the radiator, and pull it back up against the inside of the opening. Apparently when the plug is taken out this piece on the inside moves back away from the opening where the plug cannot grab it. I know a guy that replaced his rediator because he thought it was broken. Good luck
SmokinDodge12V
12-01-2002 08:44 PM
