U joint broke and broke transfer case.
Old 12-20-2009, 07:20 PM
smokeum99ta's Avatar
My u-joint on the front drive shaft broke, hit the ground, and ended up breaking the transfer case. Anyone have a place to buy another transfer case in Maryland?
Old 12-20-2009, 07:24 PM
Copenhagenjunkie's Avatar
Yours is #2, wow!
See here: https://www.dieseltruckresource.com/...e-t259754.html
Good luck!
Old 12-20-2009, 07:57 PM
Great! Is there a direct replacement that will simply bolt up or do I have to find the exact one I have now?
Old 12-20-2009, 08:03 PM
Mountaineer's Avatar
Originally Posted by Copenhagenjunkie
Yours is #2, wow!
Good luck!
Or number 3#
https://www.dieseltruckresource.com/....html?t=259891
Old 12-21-2009, 08:04 AM
Hodge's Avatar
Yep. Happened to me Friday night. Autozone sells remanufactured 241's.
My u-joint didn't break- it looks like I lost the bolts. But, when it came loose, it hit the side of the case and punched a big hole in it. I can drive it in 2WD, but there are nasty noises coming from in the case.
Old 12-21-2009, 08:18 PM
bigdave's Avatar
I had the same thing happen to me after I had the front driveshaft rebuilt. It threw parts of the transfer case out so had that they bounced off the trailer it was pulling and put a hole in the boxside just above the tail light. I put a new mopar transfer case and driveshaft in mine.
Old 12-22-2009, 05:38 PM
Fixed. I cant believe how small the transfer cases are. I was also shocked to find out that I have light duty transfer case (241DLD) in my truck. Oh well its up and running now.
Old 12-22-2009, 06:23 PM
Hodge's Avatar
Read some of the other posts about broken transfer cases. The 241LD, from what I understand, is up to the task. It is rated to handle over 5500 lb ft of torque. I am putting a LD back in mine, and am not concerned.
Old 12-23-2009, 02:04 AM
catnfool's Avatar
I just found this after posting my own carnage!! Misery loves company!!
Old 12-25-2009, 10:29 AM
Ok guys after melting all the snow and ice that was packed up in around the T-case with the little Lp torch I see that the bolts backed out and let the front shaft go and smack the very bottom corner and took out a small hole the size of a nickle. The thing is I would say all is well inside the case. I stuffed a Mcdonalds plastic bag in the hole, threw in some fluid and off the house I went. What can I do patch the hole ? Silicone ? Jb Weld ?
Old 12-25-2009, 10:33 AM
Where did you get that information ? I highly doubt it.
Old 12-25-2009, 10:38 AM
Its easier to read this way.
http://dodgeram.org/tech/specs/tranfer_case.htm
Old 12-25-2009, 03:53 PM
catnfool's Avatar
What's the verdict? Will silicone seal this up, or is there some flex that I am not considering? Mine has a crack, not a hole, but was caused by the same offending/flailing driveshaft
Old 12-25-2009, 08:28 PM
Onemoparnut's Avatar
I would have it welded up it is more of a permanent fix.
Old 12-26-2009, 05:00 AM
I would say your right. I just can't get past the thought of putting money into a case (dld) that people are having trouble with. If it was a dhd then I wouldn't think much about it.
Quick Reply: U joint broke and broke transfer case.
