Sponsored by:
Sponsored by: CARiD
Must lash valves when studding?
Old Mar 24, 2007 | 09:41 AM
trik396's Avatar
I'm slightly confused here. When I install head studs, I was under the impression that you must lash the valves afterward. And it makes sense to me since you have to remove some of the rockers which are in the way.
Yet I've read some threads where lashing wasn't required? What gives?
Old Mar 24, 2007 | 11:04 AM
ratsun's Avatar
You would probably get more response in a HP forum but for what its worth I think you would be crazy not to. It's no big deal to slide a feeler gauge in and check while your there.
Old Mar 24, 2007 | 11:23 AM
BigBlue's Avatar
If you remove any of the rockers (I took all of mine off) your going to have to lash the valves because they will be way out of whack and you could very well screw something up. Besides, with two people it doesn't take but 45 mins and my engine runs a lot smoother now that the valves are lashed.
Old Mar 24, 2007 | 12:12 PM
torquefan's Avatar
Any time you retorque the head bolts it's a good idea to recheck the valves, the lash DOES change somewhat with retorquing.
Old Mar 24, 2007 | 12:21 PM
cheapskate's Avatar
i bet i can do mine in half the time!
Old Mar 24, 2007 | 01:19 PM
trik396's Avatar
Well, I used to lash my BBC in around 10 minutes by myself because I had an underhood starter bump switch.
I'm working solo here also... and don't think I can turn over engine from up top.
Old Mar 24, 2007 | 02:28 PM
BigBlue's Avatar
45 mins was just a number. I never timed my buddy and I doing it although I'd imagine it would go pretty quick. We've only done each of our trucks 3 or 4 times a piece.
Old Mar 24, 2007 | 03:12 PM
wap's Avatar
wap
Is there a good place to get specs and procedure for lashing the valves?
Old Mar 24, 2007 | 03:16 PM
trik396's Avatar
I printed them out from a thread a while back... I'll look.
Old Mar 24, 2007 | 03:53 PM
wap's Avatar
wap
If you can find them on the net or the thread could you email em to me?
Also if you got the ARP intall in structions on file I would like to get a coppy of them too, if it isnt too much trouble.
Let em know if you got em and I can pm you my email addy.
Thanks
Old Mar 24, 2007 | 04:12 PM
BigBlue's Avatar
https://www.dieseltruckresource.com/...n&onlynewfaq=1
There's the valve lash procedure. It's really easy to do. I like doing it with two people because it makes life a little easier.
The arp install is pretty simple. Start in the center of the head and remove one bolt at a time and work your way out in a spiral manner. Once you pull a bolt out, bottom tap the hole, clean it out, then thread the stud all the way in and back it back out about 1/2-1/3 of a turn. Put moly lube all over the threads on the top of the stud and on the nut and washer and torque it down to 120 ft.lbs.
Old Mar 24, 2007 | 04:14 PM
wap's Avatar
wap
You dont lube the whole stud?
Old Mar 24, 2007 | 04:32 PM
BigBlue's Avatar
Didn't think you needed to. Figured that since the only part that's turning would be the nut so why lube the whole thing?
Old Mar 24, 2007 | 04:41 PM
trik396's Avatar
ARP suggested a little oil or moly on the threads going into the block. No loctite. He couldn't stress that enough.
Old Mar 24, 2007 | 05:31 PM
BigBlue's Avatar
Definately didn't use loctite. There was probably some motor oil down in the threads that I couldn't get out that probably worked.
