max bore and stroke
max bore and stroke
a buddy and i was talking about boring and stroking his powerstroke, we started looking all over the net for specs, couldent find anything.
got me wondering what the max we can bore our motors before any problems. what about stroking options? after market cranks?
Hey guys, I'm Timmer's friend with the Powerstroke. Right now the bore is 4.11 and the stroke is 4.18. Were thinking about doing a serious rebuild to turn this thing into an even bigger monster. I've only heard of guys going 50 over on the bore. We kind of thought maybe between 100-250 over, and going 1/4"-1/2" on stroke. 1/2" is a lot and I would probably have to get a new crank made which might not hold up with over 1,000 HP.
The block is a '97 7.3L so its got a solid cast iron block. Just looking for suggestions and ideas because it looks like no one's ever done this.
7.3 are pushing their luck at .60 over. The back two clyds are too thin. All the 7.3 that came in our shop, got the two rears sleeved. They run HOT in the back. Anything over .60 and the wall will come apart from the piston thrust. And 7.3's are bad about cracking the main webs in the outer bolt holes. Check and make sure yours is not cracked. Most of them that came in the shop were junk because they were cracked there..........
Weak mains, thin walls. Rods are weak. Sorry man..
Bought the truck new, shouldn't there be some kind of performance degrading? Cause it still runs like a rapped ape. I'm gonna tear it down to check it out.
