Mack 460 help
Mack 460 help
At work I have been selected to fix our RD688 Mack with a 460. Today began fine, as the day went on there came a slight knock in the motor. By the time we got it back to the shop it sounded like there was a midget in there beating crap with a hammer. Good oil pressure and it did not get hot. I listened around with a probe and it seems to be from the front head in the valve train. I popped off the valve cover and the only thing that I saw off was that on #2 cyl exhaust valve it seems that the spring looks a bit tilted and hitting the side of the head and the washer thing that holds the keepers is also a bit off, but the keepers are still in. SO does anyone have a idea what this could be? Are there any common problems? Thanks for the help.
It all looked fine. I just looked quick but did not see anything broke, were it did not belong. it sounds like valve train noise but seems to be a crank shaft speed, not the 1/4 speed you expect to hear with a vale.
Locomotion
Jan 25, 2005 04:47 AM
