Lower My Rpm?
Change the rear end ratio from 3.73 to 3.55 or even lower. But then I don´t know which aftermarket ratios are available.
More expensive would be an overdrive unit from US Gear or Gear Vendors.
Bigger tires would make the truck look really nice though. I think that would be the only possibilities to reduce rpm.
High Rpms
Move the driver's seat back two clicks.
The Mod is a little complicated.. But if you pull the gauge cluster apart and turn the tach clockwise about 10 degrees... it will lower the RPMS about 500-900 RPM's
It will sound the same and the speedo won't chage a bit... but you will feel better about driving 80!
OG
OG
Administrator / Scooter Bum
Originally Posted by ronc
Hey Shovelhead i tried the moving the seat back two clicks and my truck is still running a high RPM any more suggestions?
crossy
05-31-2005 12:35 AM
fishin fever
02-22-2004 08:32 PM
