Let's talk about CJ-4 Oil
#31
Well in that case, I guess around half the members of this website, including me, have sludgy, gummed up, engines. Because, I have noticed in several of the oil war threads/polls....Shell Rotella 15w40 was the top choice. Shell Rotella usually has around 45-50 percent of the total with ALL of the others, including the synthetics, sharing the rest.
There are many million mile diesel engines out there in America running on Rotella. I don't doubt that the other brands are great too. But, there may be more to that story than we are hearing here.
#32
If you read the back of a jug of Rotella oil you can see where they say depending on what fuel you use LSD or ULSD will effect your oil drain intervals. So as I understand it using LSD will shorten drain intervals when you use it in your engine, as I think the higher sulfur interferes with the oil some how and allows it to break down sooner. FYI, On road LSD can be made and sold until 2010.
#33
Here's the latest Rotella CJ-4 15W-40 UOA on BITOG. Can't wait to see more UOA's on the CJ-4 formulations.
#34
Avoid the new CJ-4 Engine Oil!
For the first time in modern history, the lattest diesel engine Oil Classification is NOT 'Backward Compatible'.
The rating is CJ-4, and the lattest is not the greatest. 07's may have to run it...not really sure, but 06's and earlier should stay away from using CJ-4 due to excessive wear to internal moving parts.
The reason - The govt in mandating catalytic converters, which appear to be unable to handle 'ZDDP' in the exhaust (a point not really proven yet!). ZDDP is a form of Zinc and is a strong, fairly inexpensive, anti wear additive that has been added to engine oils for years. Also reduced in CJ-4 is the allowable levels of calcium & phosphorous. CJ-4 must have a TBN no higher than 9, where 12 has been the norm for years. TBN # is a measure of the ability of an oil to neutralize acids formed during engine operation.
With CJ-4 in earlier diesels, premature bearing wear is showing up as early as 10,000 miles... according to a Techni-Gram I received from Lubrizol Additive Company.
This warning also applies to classification SM...for gas engines. Serious wear is showing up in race cars because...
"most all of the majors, including those who produce private label engine oils for companies such as for auto parts stores, have changed their formulas to meet SM specs."
So check labels on any oil your use to buying. Avoid CJ-4 rated oils till the facts are known, unless you have an 07 vehicle. I have not seen a virgin oil analysis on these new oils, which would verify the lower levels of zinc, calcium & phosphorous.. as well as a lowered TBN #, but until harder evidence shows up, I'm sticking with the specialty lubrication companies that are ignoring the new API classification in many of their formulas.... Amsoil, Royal Purple, etc. And be sure to read/ask about classifications before you buy.
Above is my informed opinion from being involved in the oil manufacturing industry for 11 yrs and the best data I can find...so far!
RJ
RJ
#38
Rowland-- any suggestions where someone can find off-the-shelf oil that's not watered down to meet the new spec?
I'd hate to have to keep mail-ordering all my oil. Ah, the good old days back when even Delo 400 off the shelf was great stuff!
Would this be a good time to revive the dead horse of Amsoil vs API certification?? HAHAHA!
#39
Rowland, where did you get the info? I would like to take a copy to my O'Reilly auto store. Really great guys and VERY knowledgeable.
Thanks for the heads up!
Jon
Jon
#43
They claim that if you burn ULSD the CJ-4 oil should hold up just as well as as the CI-4+ oil does and if you use LSD then you need to shorten the OCI 50%. But from what I've read from some 6.7 owners is that the oil change light comes on between 2800 and 3500 miles so it doesn't look likes its all that great of and oil or oil standard. I've also heard of some farmers no longer liking Rotella oil and wonder if they got some of the new CJ-4 oil with out knowing it and that is why they think is sucks.
All I can say is that I will keep on using Amsoil in my truck so that I know the oil will hold up and last longer then 3500 miles.
#45
What do you all think about Amsoil's 5W40 diesel oil then?
TBN:8
AMSOIL Synthetic 5W-40 Premium Diesel Oil (DEO)
AMSOIL Synthetic 5W-40 Premium Diesel Oil (DEO) is the premium choice diesel oil for model year 2007 and newer heavy-duty and pickup truck diesel engines requiring API CJ-4 emission quality oil standards.
See Pricing Information or Place an Order
Package sizes include:
1-Quart Bottle
1-Quart Bottles (case of 12)
1-Gallon Bottle
1-Gallon Bottles (case of 4)
30-Gallon Drum
55-Gallon Drum
PRODUCT DESCRIPTION
AMSOIL Synthetic 5W-40 (DEO) is the premium choice for API CJ-4 emission quality diesel oil required by model year 2007 and newer diesel engines. It delivers extraordinary lubrication in diesel engines found in commercial, fleet and personal vehicles. Built with the latest additive and synthetic base oil technology, AMSOIL Synthetic 5W-40 Diesel Oil exceeds the higher performance demands of modern engines. It withstands the stress of heat, soot and acids to help prevent deposits, corrosion and wear. AMSOIL Synthetic 5W-40, with its broad viscosity range, is ideal for winter and summer use. It resists breakdown and can extend drain intervals when monitored by oil analysis.
TBN:8
1-Quart Bottle
1-Gallon Bottle
30-Gallon Drum
55-Gallon Drum
PRODUCT DESCRIPTION
