How much electricity does a block heater use?
Just a question for those of you who may know. My electric bill has skyrocket over the last two months. the only difference in my electricity useage has been that I have been plugging my truck in nightly. Could my block heater be causing this much usage?
Yes, it sure can. I put a digital timer on mine. No more problems with high electrical bills. I think I read on here that the heater is like 6 amps and 700 watts. I know that the digital timer was recommended to handle 1000 watts.
Yes, your block heater could cause a spike, but "skyrocket"?
Are you sure your just not getting ripped by your electric company? The bill at our shop went up 60%, (YES, SIXTY, Six zero). Nice huh? They are claiming they need to recover from not hiking the rate a while ago. This is not some backwoods company either, it's Connective. :rolleyes: BG&E jacked it's rates 80%, that ought to be nice for the people who can barely pay the astronomical rates as is huh? |
My electric has more than doubled over the last two months.this past month it was 2900 kwh [eyecrazy] no changes but consistant use of block heater. Now I do keep it plugged in for about 8 hours, so I guess I will be buying a timer PDQ!
The cord on the truck is undersized as well.
They say its not, but anytime you can feel the cord temp you are seeing a restriction and losing energy that could be going to the heating element. The more efficent the block heating is the shorter the duration to get the block to temp under a given cycle/ambient temp which will save electricity. If you can cut an hour off plugging it in, say 2hrs vs 3hrs, it will add up. I put a 14 gauge cord on mine to replace the 18 gauge (I believe) that comes with the truck. Big Jimmy |
The block heater costs about 7¢ per hour to run at the national average electrical rate of 10¢ per kWh.
Of course rates vary, look for the rate on your power bill and multiply by 0.7 to find how much your heater costs per hour. |
block heater is 750 watts. which is around 6.25 amps.
It rarely gets real cold here, around freezing is usually low, once this winter down to 22F, I use a timer, 3 hours works good for me at these temps.
I plug mine in for at least 8 hours and my electric bill hasn't gone up. :confused:
I rarely plug in at the house, only if I know I am leaving early in the mornings is about the only time. However I always plug in at the hotels where I stay, so it's usually free for me... :)
And how much fuel do you use idling your truck?
The electric bill wouldn't be affected much by plugging in the heater. It would consume as much electricity as a computer, or a few bright light bulbs
Last year, my truck was plugged in every night (on a timer) - this year its rarely plugged in at all. My BGE bill(s) this year are over DOUBLE of what I paid last year. Talk about skyrocketing - my bill increases are due to natural gas prices "skyrocketing". |
I was talking to a guy in Wy that spent about 1/2 the year in Canada. He said he had a timer in his truck that would start and idle for 30 minutes every couple hours.
