Gates Fleetrunner Belts
So after 11 years, I finally changed my poor factory-original serpentine belt.
By all rights, it should have snapped years ago. It was in sad shape.
The replacement I got was a Gates Fleetrunner with the green backing. This is a REALLY impressive belt.
1) Super strong
2) Excellent heat resistance
3) No belt squeal at shutdown
If you're in the market for a new belt, do check out the new Gates greenbacks. I was really impressed!
1) Super strong
How do these compare with the "Goodyear Gatorback? I've had good luck with these for years. My last truck, a '98 12V, had one for 170,000 mi. and was still going strong when I sold it.
John
John
The gator back is a good belt, probably more readily available. None of my local suppliers stocked the Gates except my commercial class 8 supplier. If you were to hold each belt side by side the decision would make itself.
I find that the Gates heavy duty, Fleet runner belts are an exceptional value. They last a long time,wear very well and tend not to chirp at shutdown. Just add HD to the end of your belt number. They are available at Geno's. The Goodyear belts are good as well, but I found they do not last as long as the Gates Fleetrunner belts.
DTR 1st Sergeant
Fiftygrit... oooh. I'd be changing now.
Consider you have gotten exceptional life and feel good about it.
Don't wait for it to fray and split and take stuff out.
Look on the inside of the belt on the ribs... If you see a lot of cracks, it is time.
I usually change mine between 50k to 75k. I know they will go longer but its cheap insurance.. I always throw the old one under the back seat just in case I need a spare on the side of the road..
The biggest issue with the 6-8-10 groove belts is not cracking, it is the grooves wearing off the belt. It may look to be in good shape but if you were to compare it to a new belt you would notice a drastic difference in the peak/valley height.
genosgarage
Geno's Garage
04-30-2015 10:49 AM
Haulin_in_Dixie
03-09-2005 12:13 AM
1TONY1
20
08-24-2004 05:06 PM
