Ford 1210 Tractor
Ford 1210 Tractor
Tractor was running fine, then dropped down to an idle and would only idle. No RPMS. Changed fuel filter, then bled injectors, it ran fine for 10 min then dropped down and would only idle. Then I changed all fuel lines and return lines, cleaned fuel tank out, put a new fuel cap and air filter on, bled injectors again, tractor would run fine for 10 min then drop back down to an idle again. If the tractor sits over night, it will start and run fine for about 10 min and then drop down to an idle again. Anyone have any advice? Bad check valve? Bad injectors?
KBennett
12-01-2016 09:01 PM
