The Feds will force HD pickups from gas to diesel.
Interesting article how new regulations. This will ruin the HD gas trucks. I guess it will force the HD's to be diesel, no problem. I am sure the regs will make all vehicles more $$$$ anyhow. FYI
http://www.chicagotribune.com/classi...0,419500.story
It does make me laugh imagining a HD truck with small turbocharged engine, lighter frame and low resistance tires.
It probably won't be able to get out if it's own way without flexing but the low resistance tires won't grip so at least it will be able to do a burnout.
The hidden nugget at the end of the article...
It truly is the crux of the issue; how can the government get their paws on more of your money. The rest of the article is just fluff...
Of course, the report also notes that instead of requiring any complex technical changes to the vehicles themselves, the government could simply reduce fuel consumption by significantly increasing the cost of fuel through higher taxes.
What I'd rather see than diesels only in HD is a natural gas option with NG filling stations everywhere.
Pretty much goes by the name of the Pickens Plan> http://www.pickensplan.com/natural_gas/
Fuel tax revenue has been "behind the curve" since 1993 and our cowardly politicians (and stupid voters) won't raise it to cover the cost of roadways.
Fuel is already subsidized in cost, but this is flat irresponsible. The politicians are making deals to "sell" to foreigners what you and I have paid for, over and over, because the states can't even maintain, much less replace those worn out roads. That tax needs to go up substantially.
As to HD trucks being diesel, hell, ALL pickups should be. Fuel efficient, last forever and slow would be just fine.
All this technological BS is making trucks way too heavy and complicated. Look at 1st gens, will run a full ton lighter than new trucks if not more. And get 3-7 mpg better. I say throw a urea system on it and see what happens!
Don't think it needs to be a government program but maybe some tax breaks would help companies that want to get involved with NG for transportation get started.
NG pipelines already criss-cross the entire nation, new infrastructure mostly involves compressors to liquefy the NG and stations to dispense it.
Converting any engine to run on NG isn't that hard nor expensive. Biggest expense and challenge is a new tank.
Main problem is it makes too much sense, something that this country seems to be currently lacking.
Yea but according to the fox news article I seen about that NG explosian down in the Calif. bay the ng pipeline that are burried across the country are 40 to 50 years old & have a life expectancy of 50 yrs. So whats the cost of replacing all these ageing lines & adding more to them?
