Sponsored by:
Sponsored by: CARiD
View Poll Results: Do you recycle waste oil? (In the present, not 1970's)
I recycle it and all my friend do.
129
70.49%
I recycle it but know people who don't.
38
20.77%
I bury it behind the 'ole shack, my friends do the same.
16
8.74%
Voters: 183. You may not vote on this poll
Do you dump your waste motor oil in the ground?
Old Jun 25, 2008 | 06:38 PM
  #46
cmac's Avatar
i recycle all of my oil.... be it in the tank or at the parts store..... however back in the day when my uncles used to Log they would dig a big ol hole, drive the skidder over the hole and drain the oil in it.... fill er back up and fill the hole in.
Old Jun 25, 2008 | 11:17 PM
  #47
dfranks's Avatar
I flush the stuff down the toilet, Got tired of the smell of diesel in the garden.
Old Jun 25, 2008 | 11:28 PM
  #48
iker42's Avatar
use it to fill in pot holes
Old Jun 26, 2008 | 03:11 AM
  #49
wcbcruzer's Avatar
I'm sure you do. lol...
Old Jun 26, 2008 | 05:29 AM
  #50
12 flapper's Avatar
mine helps my garbage burn use a little and it burns everything in the burn barrel, my granddad uses it to keep the dust down in the driveway
Old Jun 26, 2008 | 07:20 AM
  #51
nhboyd's Avatar
used oil
is used in a waste oil burner to heat shop.
Old Jun 26, 2008 | 07:25 AM
  #52
Palmetto_kid's Avatar
I live close to a refinery, and they have an oil dump facility that supposedly runs the waste oil back through the cat cracker. I have been told that when it was originally opened up that it was for employess as well as the general public. But, they dont advertise it, and the site is inside the fence and past the guard gate.
I need to check into it, becuase I have 2-55gal drums full, and am beginning to fill up 5 gallon buckets!
later...
Old Jun 26, 2008 | 07:51 AM
  #53
BIGDAN65's Avatar
Originally Posted by blackcloud
I recycle it now but I remeber back when I was five or six (23 now) and I used to help my dad change oil on stuff he would dump it along the side of the garage. Maybe thats why our water tasts funny, lol
that is exactly what my dad did too, he would have me pour it around the shop on the wood seal, he said it would keep termites out i do not know how true that is but i did it. this is the first diesel in my family so we only had to deal with 5 qts. having to dispose of 3gal is one reason i let MR Lube change it now the other is time
Old Jun 26, 2008 | 05:19 PM
  #54
Desert Dually's Avatar
later...
you own a 12 valve, so you potentially are sitting on 110 + gallons of fuel!!!! At nearly 5 bucks a gallon, that is 550 dollars.
buy yourself a ½ micron filter sock and drip that waste motor oil "WMO" thru the sock and pour it into your truck's fuel tank. It will NOT know the difference! I know 2 guys who are currently doing this with no problems for several years now. They also run used hydraulic oil in their trucks.
A lot of you guys with 12 valves, especially the older mechanically injected ones, can run WMO at like 60%. It has more BTU's when burned, than diesel fuel.
Old Jun 26, 2008 | 05:50 PM
  #55
johnny5.9's Avatar
What's are you guys changing the oil in? I don't get waste oil from anything around my house. JK
Old Jun 27, 2008 | 10:58 AM
  #56
Nick02Ram's Avatar
I always used to save it all up and dump it into our waste oil heater at work. Now that I got our wood boiler goin I dump some in there occasionally to keep her hot. I'd like to find some kind of pump to where I can just dump it into a barrel and inject it right into the fire.
Old Jun 27, 2008 | 11:26 AM
  #57
Haulin_in_Dixie's Avatar
Gotta teach these yankees everything. The red neck central heating system is a barrel with a door, some bar b cue lava rock for the bed and a copper line running over it with a valve and the oil higher than the stove. You crack the oil line and light it, the lava rock gets hot and vaproizes the oil as it drips down. Worked in one dealership where this was the heat system for a very big building.
Old Jun 27, 2008 | 11:27 AM
  #58
Oh yeah you need a stove pipe if you want to breathe too,.
Old Jun 27, 2008 | 10:27 PM
  #59
Mcmopar's Avatar
You are too funny, you can breath carbon monoxide for a little while!!!
Old Jun 27, 2008 | 11:01 PM
  #60
HOHN's Avatar
Since so many placed take waste oil now (parts stores or city facilities) it's really hard to justify not taking it in.
If I can recycle it, anyone can.
JMO
