dash light on
i have a 2007 dodge 6.7 l 3500 6 speed manual trans just got the 5inch exhaust, efi live 5 position switch and kn cold air, egr,cat, dpf,and thr control valve deletion done about 6 months now. i have the abs and brake light that comes on and if i pull over shut it off and restart and go down the road a 1/4 mile it will clear and sometimes come back on. it doesn't matter if i am towing anything or not. looking for what it could be or what is the cause. any answers from you all?
Originally Posted by Jeff Magargee
(Post 3309672)
I had one that set a code for a bad check valve. I discerned that the fluid had been in the system for some time, had the local shop flush it and clear the codes, and it stayed clear. They thought I was nuts. I said, "I'll sign the check." |
