Sponsored by:
Sponsored by: CARiD
Crazy transfer case ?
Old Mar 21, 2007 | 11:33 PM
hotmopr's Avatar
Has anyone ever tried to rotate a trans case 180* on a nv4500? Will it bolt back on? Reason for asking is my dad is building a little toy. The chassie has a passenger side front diff pumpkin, instead of normal dodge driver side diff pumpkin. If somebody has a trans and transfer case out could you try it for me..
Thanks, Adam
Old Mar 21, 2007 | 11:35 PM
kawiram's Avatar
How would you run the shifter linkage though? Unless it's electric dialed
Old Mar 21, 2007 | 11:47 PM
hotmopr's Avatar
Its all custom so I guess it would just be on the other side of the shifter..
Old Mar 22, 2007 | 08:29 AM
chromegrill's Avatar
How will the T-case pump fluid upside down? Your best bet would to be to use a case with that side drop. Dana 300, 20 come to mind...
Old Mar 22, 2007 | 08:48 AM
CTD NUT's Avatar
It won't work....as chromegrill said, it won't oil because the pump will run dry.
wyododge
Aug 18, 2011 07:48 AM
Atlantic4x4
Sep 8, 2006 09:20 AM
8mpg
May 22, 2006 01:35 PM
