Compliance info for 2007 ULSD
More THINGS YOU NEED TO KNOW ABOUT EPA 2007
EMISSIONS REQUIREMENTS NEW DIESEL FUEL DESIGNATIONS & USAGE This information is supplemental to “Six Things You Need To Know About EPA 2007 Emissions Requirements” sent to you by MEDTEC Technical Services several months ago. Ford Motor Company has released a Special Service Message #19244 stating the following: “All 6.0L Diesel E-Series, F-250-550, 6.0L/5.0L Cummins/7.2L Cat Diesel F-650/750, and 4.5L Diesel LCF vehicles have a “carry-over” 2006 style engine and are not required by federal mandate to use the Ultra Low Sulfur Diesel (ULSD) fuel. Until ULSD (15-ppm S) is available in October 2006, all diesel fuel pumps selling Low Sulfur Diesel fuel (500-ppm S) must use newly established labels by EPA beginning June 1, 2006. The labels for these pumps state: “WARNING Federal law prohibits use in model year 2007 and later highway vehicles and engines.” This is not the case for 2007 vehicles with the carry-over 2006 engines; therefore, both Low Sulfur and Ultra Low Sulfur diesel fuels can be used in these vehicles. For additional information on the upcoming change to diesel fuel formulation, please visit http://www.clean-diesel.org/ .” NOTE: The following articles are excerpted from the Clean Diesel Fuel Alliance website. Ultra Low Sulfur Diesel will be the primary highway diesel fuel produced. The full transition to ULSD fuel is complex and involves coordination at many levels. Under the new EPA standards: • Refiners and importers nationwide must ensure that at least 80 percent of the volume of the highway diesel fuel they produce or import is ULSD-compliant by June 1, 2006. • Diesel fuel classified as ULSD must reach distribution and marketing points downstream from refineries (i.e., pipelines, distributors, terminals and transporters) by September 1, 2006 (July 15, 2006 in California). • ULSD fuel is expected to be available at many retail locations by October 15, 2006 (September 1, 2006 in California). 2 • Diesel fuel classified as Low Sulfur Diesel fuel may still be sold at retail locations outside of California between October 15, 2006 and December 1, 2010. • The State of Alaska has received an extension of the highway fuel 15-ppm requirement. Effective Dates for Highway ULSD Fuel Who What U.S. California Import/produce at least 80% ULSD for on highway use 6/01/06 Refiners & Importers Import/produce at least 100% ULSD for on highway use 6/01/10 6/01/06 Facilities that choose to carry ULSD must meet 15 ppm sulfur specification 9/01/06 Downstream from Refineries through Fuel Terminals All highway diesel must be ULSD 10/01/10 7/15/06 Facilities that choose to carry ULSD must meet 15 ppm sulfur specification 10/15/06 Retail Outlets All highway diesel must be ULSD 12/01/10 9/01/06 Although ULSD fuel will be the dominant highway diesel fuel produced, EPA does not require service stations and truck stops to sell ULSD fuel. Therefore, it is possible that ULSD fuel might not be available initially at every service station or truck stop and that a diesel retailer may choose to sell Low Sulfur Diesel fuel instead of ULSD fuel. The industries involved in the transition are doing all they can to minimize potential inconveniences during the conversion to the new diesel fuel. Federal regulations require the labeling of all diesel fuel pumps to specify the type of fuel dispensed by each pump (except in California where all diesel fuel must be ULSD by June 1, 2006). Similar instrument panel and fuel inlet/fill cap labeling is being mandated for 2007 and later model year highway engines and vehicles that require ULSD fuel.* Consumers are advised to check the pump and vehicle labels to ensure they are refueling with the proper diesel fuel consistent with their vehicle warranties. The new standards provide strong incentives for suppliers to provide the proper ULSD fuel formulation. Civil penalties of up to $32,500 per violation per day can be assessed for noncompliance with EPA’s ULSD fuel standards, or for misrepresentation of the sulfur level of diesel fuel. *Exception – Some 2007 model year medium-duty and heavy-duty trucks may be equipped with 2006 engines and emission systems. These vehicles are not required to use ULSD fuel. Ultra Low Sulfur Diesel is compatible with existing fleets with comparable performance. Owners of 2007 and later model year diesel-powered highway vehicles must refuel only with ULSD fuel.* Owners of 2006 and earlier model year diesel-powered highway engines and vehicles may use ULSD or Low Sulfur Diesel fuel during the transition period. Only ULSD fuel will be available for highway use starting on December 1, 2010. View PDF of Pump Labels 3 Under typical operating conditions, there should be no noticeable impact on overall power using ULSD fuel. Fuel economy may be reduced slightly because the process that removes sulfur also can reduce the energy content of the fuel. Engine and vehicle manufacturers expect ULSD fuel to be fully compatible with the existing fleet, including 2006 and earlier model year vehicles. In some instances, the introduction of ULSD fuel to older vehicles may affect fuel system components or loosen deposits in fuel tanks. As part of a good maintenance program, owners and operators of existing cars, trucks and buses are encouraged to monitor their dieselpowered vehicles closely for potential fuel system leaks or premature fuel filter plugging during the changeover to ULSD fuel. Like Low Sulfur Diesel fuel, ULSD fuel requires good lubricity and corrosion inhibitors to prevent unacceptable engine wear. As necessary, additives to increase lubricity and to inhibit corrosion will be added to ULSD fuel prior to its retail sale. With these additives, ULSD fuel is expected to perform as well as Low Sulfur Diesel fuel. Diesel-powered highway engines and vehicles for 2007 and later model years are designed to operate only with ULSD fuel. Improper fuel use will reduce the efficiency and durability of engines, permanently damage many advanced emissions control systems, reduce fuel economy, and possibly prevent the vehicles from running at all.* Manufacturer warranties are likely to be voided by improper fuel use. Additionally, burning Low Sulfur Diesel fuel (instead of ULSD fuel) in 2007 and later model year diesel cars, trucks and buses is illegal and punishable with civil penalties.* Only ultra low sulfur kerosene (No. 1 diesel with no more than 15 ppm sulfur) may be blended with ULSD fuel to improve cold weather performance. With so many kerosene formulations on the market, care must be taken to select kerosene with a maximum of 15-ppm sulfur. Blend rates will remain the same as with Low Sulfur Diesel fuel. Most engine and vehicle manufacturers allow bio-diesel blends in concentrations up to five percent provided those blends meet accepted (ASTM) fuel quality standards. (Biodiesel blends are mixtures of petroleumbased diesel fuels and fuels produced from soybean oil, waste cooking grease, or other organic matter. These fuels may contain bio-diesel in concentrations ranging from two percent to levels approaching 100 percent by volume.) To ensure proper quality, consumers should use only bio-diesel-ULSD fuel blends that are properly mixed by a qualified bio-diesel blender. Consumers should not create their own bio-diesel blends by adding bio-diesel to ULSD fuel in a vehicle’s fuel tank. There should be no operational problem if consumers switch from a bio-diesel-ULSD fuel blend to ULSD fuel without bio-diesel. *Exception – Some 2007 model year medium-duty and heavy-duty trucks may be equipped with 2006 engines and emission systems. These vehicles are not required to use ULSD fuel. MEDTEC Technical Services 7/10/06 K. Alan McFerren, Technical Services Manager (574) 534-2631 ext. 3418 or amcferren@medtecambulance.com API Suggested Diesel Pump Labels Compliant with EPA 40 CFR 80.570 • Titles of all labels (e.g., Low Sulfur Highway Diesel Fuel) are in 24-point type, Sulfur Level Cap Designations (e.g., [500 ppm Sulfur Maximum]) are in 20-point type, and all other required language is in 14-point type as approved by the EPA. • Green is chosen as the background for the first two labels because of its strong association with diesel in the gasoline service station network. • Labels shall be on the upper two-thirds of the pump in a location where they are clearly visible. • Pumps must be labeled by June 1, 2006. |
