Common Fuel Filter Data
Thanks AH64ID.
Baldwin BF1259 (F/W):
90 gph SAE Ji985 10um, 99.9% contaminant removal exceeds Cummins 98.7% spec
98.9% Emulsified Water Removal exceeds cummins spec of 95.0%
55.1g holding capacity exceeds 52.0g spec.
Also appears to exceed the BF1212 and the Fleetguard FS1000.
I have run it on my Fass 150/150 so I know it fits - Thread 1-14, OD 3 11/16, length 9 19/32 (note it is a longer filter).
Seems to be the way to go for a FW on the Fass 150/150 IF a good filter is used and the install can accommodate the length.
I just ordered filters for my Airdog 100 and went with the Baldwin BF1275 and Donaldson P551315. I am still using the PF7977 in the factory can for my last chance filter. Hope this helps with injector life.... Suckers are too expensive to have to rebuild them every 87,000 miles.
AH, have you seen this one FF5782?
It states 98.7 of all particles as small as 4 micron.
According to the mag I am lookin at it also says "shows no signs of injector wear at more than 190 hrs of testing."
I am here: http://tapatalk.com/map.php?prna2i
2003 Ram with gauges and a Smarty! Not much more.
Sent from my iPhone using Tapatalk
Got my filters in today. They are going on the truck tonight as long as I don't get rained out...LOL
Thanks Ah64ID for the research. I got the best I could get until any new ones come out.
Just had one issue on the install. Had to move the pump assembly over a bit. The Donaldson filter was hitting on the mounting bracket and wouldn't seal up. No issues other than that. I did loose about .5 to 1 psi of fuel pressure. No biggy though.
I've been running the drop in filter elements since 2000. Until I went to the Balwin PF 2-5 micron seris, all my filters were always tan in color when removed at 10,000 miles.
Ever since I changed to Bladwin everyone has been black when removed. So for sure the Baldwin Filter is doing a better job.
Dave
Dave
mhuppertz
Nov 27, 2010 06:23 PM
