Sponsored by:
Sponsored by: CARiD
Checking rear axle straightness???
Old Jun 6, 2015 | 09:53 PM
SIXSLUG's Avatar
I'd guess that is possible. Its only straight in one spot, any bend would show double by wobbling the shaft at the other end I'm thinking
Old Jun 7, 2015 | 06:26 AM
BigIron70's Avatar
Cummins Guru
We have been checking for bent axle using our alignment machine, but if axle is not bolted to truck spinning hub should work for a quick check. We recently changed front axle because we were unable to get alignment into spec. New truck under warranty.
Old Jun 7, 2015 | 03:37 PM
NE frmhnd's Avatar
That would work for the axle shaft, but not the housing. If the shaft is bent, it will wobble. The housing can be bent without any wobble.
Providing there is not excessive play in the wheel bearings, the hub just takes the place of your lathe.
nvr-enuf
Jan 30, 2014 06:56 PM
ian515
Jul 24, 2009 03:22 PM
mudwisr2
Feb 22, 2008 11:51 AM
MX429
Aug 20, 2006 06:41 PM
Paul Winey
Jun 22, 2004 08:09 AM
