Bosch VE IP Dual Throttle Return Springs
Old 02-03-2018, 02:10 AM
man630's Avatar
I’m Changing the throttle shaft o-ring and bushing on a Bosch VE Pump (VW 1.6 NA Diesel). Throttle levers are indexed, fuel pressure screw marked and measured with digital caliper. The only issue stopping me from removing the Governor cover is those 2 Big Green Throttle Return Springs, any info on how to remove and reinstall them correctly would be appreciated. One post I found said to tie them together with a zip tie’s as you remove them to keep them in correct alignment. Will post photos once I figure out how to do it on this site.
Thanks
Randy
Rick 12v CTD
09-23-2011 05:21 PM
Scotts_D250
07-10-2011 01:05 AM
ctd4stan
05-18-2009 02:56 PM
53 willys
23
05-19-2008 06:14 PM
Jim5870
07-15-2006 01:32 AM
Quick Reply: Bosch VE IP Dual Throttle Return Springs
