Burning/using oil question..
Old 10-22-2002, 05:30 AM
thatguy's Avatar
I have a friend that has a 2000/2001 F-250 Ford diesel, with under 100,000 miles.. He is doing oil changes about every 10,000 miles and using Delo oil..<br><br>At 7,200 miles he had to add about 3 to 4 qts of oil. Does this seem excessive? Im thinking the oil is just getting quite then by that mileage - BUT to me that seems to be borderline high usage for that many miles... <br><br>Any thoughts? thanks.<br><br><br><br>
Old 10-22-2002, 07:52 AM
withers's Avatar
Re:Burning/using oil question..
Sound excessive to me, I do oil changes twice as often as I have to because the truck has to last me a long time, but I've never had to add ;D a drop of oil between changes.
Old 10-22-2002, 10:33 AM
DieselDennis's Avatar
I think it's probably the injector 0-Rings giving way. Not a real bad expensive part to replace, about $8 a cylinder I think. Just very time consuming to open up the valve covers and pull out the injectors. A good way to check this is to get an oil sample and put drop a drip of it on a clean white sheet of paper. If you get two rings ( a black one on the inside, a red one on the outside) then it's likely that the oil is actually leaking into the fuel past the 0-Rings. I think Ford's spec for oil usage has to be more than half quart per 800 miles. <br><br>And I also suggest that he check his dipstick more often. He shouldn't be adding more than 2 quarts a time or his engine is running low on oil.<br>
look171
12-30-2010 07:31 PM
deereman
10-04-2003 07:07 AM
CumminAtYa
03-11-2003 12:00 PM
hvanflee
01-23-2003 07:22 PM
hvanflee
01-14-2003 12:20 AM
Quick Reply: Burning/using oil question..
