99 Powerstroke Missing
What you are describing sounds like to me a deffinite miss, a cps will absolutely, positively not cause this. A cps failure will cause a stalling and a no start condition on that engine, if you had a cps code on your scanner then I would lean toward it being a culprit only because it has proven to be a reliable trouble code, and that is only if the engine is stalling or no starting.
A cylinder contribution test, or an injector buzz test can be misleading, and most aftermarket scanners cannot perform the required tests to isolate what injector is having an impending failure. My best guess would be a #8 injector with an impending failure, it is a long lead injector because it is the last one to get fuel, and is the one that is most prone too failure.
A Ford scanner may be your best option.
Best of luck for a speedy resolution.
Not true. When a CPS begins to the failure oftentimes begins intermitentently. The no start condition is when tthe CPS is 100% failed. Stalling and missing is the CPS beginning to fail. When my CPS started to go failed (at approx 110K miles on the truck), my truck had a 'miss'. Replaced the CPS & the 'miss' went away.
We ended up pulling all of the injectors and sent them to M&M for testing and rebuild. Our mechanic is betting on a bad #8; we shall see. I still think we should have swapped the CPS, cheap and easy idea.
Cps should throw a code, but it doesn't always happen. I had 2 go bad on 2 different trucks and niether gave a code. Others I know have seen the code pop up on their trucks before the CPS totally crapped out.
Sarge1124
Dec 3, 2002 04:24 PM
