Sponsored by:
Sponsored by: CARiD
12valve block 24valve head?
Old Mar 6, 2007 | 03:18 PM
Tmc243's Avatar
Is it possable (within reason) to install a 24 valve head on a 12 valve engine? Seems like this would be the best of both worlds. Dependability of the 12 valve and the air flow of the 24 valve. If a 7100 pump can be installed on a 24 valve engine why can't a 24 valve head be installed on a block built for a 12 valve head?
Old Mar 6, 2007 | 03:36 PM
Forrest Nearing's Avatar
injector location requires a different piston
Old Mar 6, 2007 | 03:37 PM
you're much better off porting a 12v head... the valvetrain is MUCH cheaper
Old Mar 6, 2007 | 03:38 PM
Tmc243's Avatar
So if the pistons are change out to the 24 valve pistons it should work?
Old Mar 6, 2007 | 03:39 PM
Tmc243's Avatar
Current head is cracked so I'd have to get another head anyway.
Old Mar 6, 2007 | 03:54 PM
yes, I'd recomend using Common Rail pistons... you'll need custom injection lines and custom injectors. I would still recomend going w/ a ported 12v head for simplicity's sake. the RV valvesprings have proven to over 4,000rpm and they're like $100 a set... a good set of 24v springs will cost $500-600
do what you will, I'd LOVE to have a p-pumped CR block. those pistons will support a LOT of timing!
Old Mar 7, 2007 | 05:34 AM
74dart's Avatar
what are and where do you get the rv valve springs?
Old Mar 7, 2007 | 09:55 AM
they're the 60lb e-brake springs. they're a heck of a spring actually.. beehive shaped etc.
rbrettctd
Sep 2, 2007 07:59 PM
SilverSootXpres
May 8, 2007 08:53 PM
GCSS
Apr 27, 2006 10:45 PM
storx
18
Feb 10, 2006 10:33 AM
RUSVD
Jun 8, 2004 07:25 PM
