Got WMO filter setup running!!
I finally got my setup and and running and it's great! I'll try to get pictures. It has a 8 or so gallons resivoir where air pressure (only about 10 psi does the trick beautifully) pushes down and forces it up a tube into and parallel tank that has a 1 micron filter thats is like 16" tall by 10" in diameter. Through the filter it goes and then through a 15 micron water separater from Tractor Supply. I only really need it for the water separater. At the bottom is a peticok to drain the water when I see it's getting tall. Works GREAT though, fill up before this one I had 7 gallons and this fill up I put 10 gallons in. Smoke is kinda getting out of hand so I have to tweak th IP a bit to tone it down, but I keep my eye out for the cops. I do tow but not often, but when I do go to tow I'll make sure I'm running straigh diesel to be safe!
10-28-2012 12:39 PM
Mark Hodowanec
13
02-17-2010 01:53 PM
Jeremy Cusick
05-13-2004 07:43 PM
